Re: Max 2600RPM???
Jim,<br /><br />You might want to consider a process of ellimination starting with the easiest/ least expensive and moving on from there<br /><br />Here is a way to check the gear ratio of your drive so you can eliminate it from the list of possibilities:<br /><br /> http://www.mercstuff.com/drivegearratio.htm <br /><br />Then go out and beg or borrow a 15p prop and eliminate that as the possibility.<br /><br />Then go out an spend the $ for a new carb.
