Martin 7.5 Twist shift
Mas
I've been trying to rebuild a Martin 7.5. The lower piston is seized due to water. I was able to pick up another powerhead for cheap...but the pistons were seized as well due to water. I do not know if I've got bad luck or if water entry was a problem with these Martins!?
Question: Where is the "weak spot" for water entry on these motors? during the autopsy I did not see anything obvious.
Any insight from those who know Martins?
MAS
steelespike
Re: Martin 7.5 Twist shift
Pretty sure there is a guy at www.aomci.org that knows the Martins in and out. Haven't heard anything but good news about the Martins.Though any motor that has been overheated could ingest water.
Mas
Thanks...I'll see what they have to say.
Mas
