Mariner Wash through
Tim Ray
I have a 9.9hp Mariner. I currently run it in a large tank after use in the Sea to clean the salt water off. This is a pain to fill and empty (particularly as the engine has hydrofoil large fins that have to be removed to fit it into the tank) Is it possible to get any kind of an adaptor to connect the engine to a hosepipe and run it with a cold water supply in this way?
joed
Re: Mariner Wash through
You mean like this from basspro
[http://www.basspro.com/webapp/wcs/stores/servlet/Product_10151_-1_10001_45219_200002007_200000000_200002000_200-2-7[/url]
achris
More fish than mountain goat
Those flushers don't fit on the 9.9 Mariner. The water intake is under the cav plate. Since you have a hydrofoil (something I strongly recommend you remove, and leave off) the flushers for those engines won't go on anyway.
Chris...........
Tim Ray
Thanks for the responses guys.
Two questions really, 1/ Is there ANY device that fits the 9.9 Mariner that will let me wash it through with a hosepipe?
2/ What is so wrong with a hydrofoil? Is it just wrong for this engine or is there a bigger issue?
Thanks
Tim Ray thecritix@aol.com
Laddies
Banned
In most cases the hydrofoils rob preformace they do help get on plane but thats it. Tempo builds a flush attachment for your engine
achris
Hydrofoils generate lift and that lift is transfered through the engine to the stern of the boat, and therein lies the problem.
The engine swivel bracket and clamp brackets are designed to take load in the down direction, not transfer lift. I have seen terrible damage done to engines because of these things. A lot of broken cav plates and swivel brackets.
Aside from the damage is the issue of stern lift. Yes it will help achieve planing easier, but as boat speed increases the lift generated increases, and can cause a dangerous 'bow steer' condition, leading to broaching.
'Nough said,
Chris............
Tim Ray
Thanks for all your help, looks like the hydrofoil is coming off!!!
Tim
tashasdaddy
if you have planing problems, look into smart tabs, for the boat. correct solution to the problem.
achris
Hi Tim,
Finally found the flushers for your engine. The part number is -12612T2.
Cheers,
Chris..........
