TACOMATruckin98
- Apr 4, 2007
- 12
Hi everyone, I do not post much here, but just browse from time to time. I have at the beginning of last summer purchased an 84 Procraft 1750 with an either 83, or 84 Mariner V-150 V-6. The motor ran great all summer until the last time we took it out a few months ago. I do not know any of the maintenance history of the motor, but it looks to have been pretty well maintained. The last time we took it out, the boat was running great, no problems with power at all, but I noticed after warmup and a probably 85% throttle run straight across the lake probably 3/4 mile, we pull up to our fishing spot and there is only steam coming out of the exhaust. Strange, but I thought maybe a wave just hit the exhaust when we stopped because there was no alarm or loss of power. Well we went back to the dock to grab a snack after a while, no problem starting at all. Got back to the dock pulled up, and there was steam again, no alarm at all, no cutback in power, nothing, but when I went to start the motor right back up, it turned over and started, but as soon as the key was hit the very loud alarm went off. Knowing I couldn't blow this motor, I shut it right back off, tilted it up and checked that there was nothing wrapped around pickup and there was nothing. After letting it cool off about ten minutes, I cranked it up checked the tell-tale, which seemed to be perfectly fine, and started slowly back across the lake, just barely on plane and had my buddy on the back deck to watch the exhaust/tell-tale, and I leaned down to make sure no alarm. Seemed fine so I pushed it on up to near WOT, never heard any alarm at all, no power reduction, but started steaming again so we stopped and allowed it to cool about 5 minutes and there was no alarm at that point with the key turn. Tested the compression, 120-123psi across all 6 cyl's, no tell-tale reduction, no overheating at all running at idle for almost 20 minutes. I know that I will replace the impeller before the season, but I need to know if that is my only problem, so I replace everything I need to while I'm in there. Also, the prop looks to be marked as a Turbo M14 1/2 x 2Y? And attached are pictures of the motor height on the transom to try to make sure to rule out everything. Thanks for any help!
