Mariner to Evinrude conversion..
billh1963
Yes, I've searched the archives :)<br /><br />I'm converting my Boston Whaler Montauk from a 1980 80hp Mariner to a 1991 90hp Evinrude. I know that the "normal" controls aren't interchangeable but the Whaler has the top mount kind that looks generic. Are these engine specific as well? Do I need a new one to change the engine or is it a matter of a control cable swap? The Mariner doesn't have T&T but the Evinrude does (hence, the swap).<br /><br />Thank you!
93bronco
Ensign
Re: Mariner to Evinrude conversion..
you would actually have to find out the original maker of the control to sea if it is compatible.<br />(morse, teleflex)<br />i had the same question when finishing a force to omc swap that was started when i bought my boat.<br />-<br />the us marine side mount control was basically the same as a morse SL-3 side mount, just older.<br />i changed it because i didnt know it was compatible.<br />the omc motors have a different stroke positon at the control.<br />you could pull yours out to sea if there are adjusting/alternate holes on the throttle & shift arms.<br />-<br />i stand to be corrected, but that is what i found out.<br />-<br />if it was manufactured by morse it could be as easy as getting morse control or cable adapter kit to accommodate the installation.<br />-<br /> the tilt/trim switch is easy, instead of payng $50+ for a steering wheel switch, west marine (or maybe this site has one)<br />has a weatherproof transom switch that can be mounted anywhere for $20.<br />its alot better than the one in my side control.
billh1963
Thanks, 2K.<br /><br />Anyone else have any experience with this type of conversion they would like to share?<br /><br />Thanks!
ob
If your montauk has a center console you might consider finding either a new or used OMC binacle style control.It will have the alarm horn within and key start primer that will be compatible with your engine.
