Re: Mariner Magnum 40
not very hard here is the stator test for 40 HP 4 cylinder Find your stator number to test which one you need below Battery Charging System
Troubleshooting
A fault in the battery charging system usually will
cause the battery to become undercharged. Check
battery electrolyte level, and charge battery. See
?Electrolyte Level?, and ?Charging a Discharged Battery?,
preceding.
If battery will NOT accept a satisfactory charge, replace
battery.
If battery accepts a satisfactory charge, determine
the cause of the charging system problem as follows:
Visually check the following:
1. Check for correct battery polarity [red cable to
positive (+) battery terminal]. If polarity was incorrect,
check for damaged rectifier. See ?Rectifier
Test?, following.
2. Check for loose or corroded battery connections.
3. Visually inspect wiring between stator and battery
for cuts, chafing; and disconnected, loose, or
corroded connections.
4. Excessive electrical load (from too many accessories)
will cause battery to run down.
If visual inspection determines that battery connections
and wiring is OK, perform the following stator
and rectifier test:
Stator Test (Alternator Coils Only)
NOTE: Stator can be tested without removing from
engine.
1. Disconnect both yellow (stator leads).
2. Use an ohmmeter and perform the following test.
3. Replace stator if readings are outside ranges
shown.
STATOR TEST (BLACK STATOR)
9 AMP Stator (398-818535A5)
Test Leads To ? Ohm
Scale
Ohm
Reading
YEL and YEL R x 1 .8-1.1
9 AMP Stator (398-8778A_)
Test Leads To ? Ohm
Scale
Ohm
Reading
YEL and YEL R x 1 .5-1.0
16 AMP Stator (398-9710A33 & 398-9710A42)
Test Leads To ? Ohm
Scale
Ohm
Reading
YEL and YEL R x 1 .10-.50
STATOR TEST (RED STATOR)
Electric Start Engines 9 Amp Stator
Test Leads To ? Ohm
Scale
Ohm
Reading
YEL and YEL R x 1 .4?1.0
Electric Start Engines 16 Amp Stator
Test Leads To ? Ohm
Scale
Ohm
Reading
YEL and YEL R x 1 0.165?0.181
Manual Start Engines
Test Leads To ? Ohm
Scale
Ohm
Reading
YEL and YEL R x 1 0.17?0.19 PS I Have the Red stator 16 amp
