My 91 Mariner 150hp mariner (ser# ODO320093) suddenly starting idleing high and throughout the day the idle increased.. This made it difficult to put the engine back in neutral. When I kill the motor it goes easily into neutral. Once I have it in gear and increase rpms, it runs great all the way up to wide open throttle. I searched the various forums and found the suggestions on kinked shifter cable but it appears to be fine. The idle adjustment is sitting against the stop but when I start it up it immediately revs so high I'm scared to let it run to trouble shoot. I read an old thread about a very similar problem with a 97 Mariner 150hp where the owner reset the idle setting but mine was fine where it's set so I can;t help but think that if I try readjusting it, I would just be working around the real problem. Can anyone point me in the right direction to start troubleshooting?
Thank you.
Thank you.
