mariner 90 inline 6 (1986)
FatCapt.
i need the carbs rebuilt on my inline six, does anyone know an average cost to have this done? if i have a repair manual is it difficult to do myself?
Georgesalmon
Re: mariner 90 inline 6 (1986)
get the kits and manual here on iboats, get new floats, don't come in kit. Do it yourself, very easy.
CaptainD101
easy if you got the right tools and knowledge. I just finished my 1986 inline 6 and was not the easiest carb job. although after I was done yes it was easy. Just finding the right 1/4 drive socket was annoying, and adjust the butterflies was a little tricky. What does the manual say for the idle screw adjument?
Chris1956
Honorary Supreme Mariner
idle mixture adjustment is a bit tricky, until you know the secret and have some patience and calm water to adjust it. Set the idle mixtures to 1-1/2 turns out from lightly seated. Launch, warm and run the motor in the lake/bay. Adjust the idle screws a bit at a time to achieve smoothest, fastest idle speed. Now try to accelerate. Normally the motor will stumble, due to being too lean. Open the top carb 1/8 turn and try to accelerate. Repeat with mid carb, and then lower carb, testing acceleration after each adjustment.
