Mariner 75 year
Ady B
Hi I have a 3 cylinder mariner 75 but dont know the year to get the right repair manual. The serial no. is 0C215558. any help appreciated. Thanks Ady B.
Ady B
Re: Mariner 75 year
Thanks Laddies for the quick reply.
jmburock
Re: Mariner 75 year
I have the exact same motor- 1989 Mariner 75hp 3cyl. Definitely buy the Mercury branded manual. Any problems with your motor? I've done almost everything that could be done to mine so let me know if you're having any problems.
Ady B
Re: Mariner 75 year
Ive been using a Clymer Mariner 1990 to 1993 manual so the problem may be there as my engine is a 1989. Ive service water pump, fuel pump, and carbs and have followed manual for timing pointer adjustment, carb sync, timing etc. Engine starts ok but needs very little choke even when very cold, runs ok for a while then chokes up bad, but can be cleared with revs. Have adjusted carbs to very lean (about 1/4 turn on idle mixture screws), but plugs still wet and black. I was thinking of trying the Seloc online manual, any ideas.
Ady B.
