Mariner 4hp - Stop button to kill cord?
Adf
Hi everyone,
Is it possible to retro-fit a Mariner 4hp 2 stroke (see picture), with a kill cord instead of a button? If so, is it easy to do? I know you can buy generic kill cords (like this Seadog Universal Kill Switch - iboats), but I'm just not sure if it would work.
Thanks.
gm280
Re: Mariner 4hp - Stop button to kill cord?
Hi everyone,
Thanks.
I would assume you could if you know anything about how your ignition system works. You could install the actual kill switch in the front of the engine and use the pull cord like any other kill switch setup in any boat. Those kill switches usually are setup to either short the two ignition points together stopping any spark to the spark plugs OR it shorts the input to the CDI system grounding it from working. I don't know which your is. So you would have to figure that out... But my honest answer to your question is sure... :)
