Mariner 30 hp/What year is it?
bwargo
Hi all...I am trying to do some work on this Mariner 30 H.P. outboard and do not know what year it is. The serial number is 69S 108426 Model # 30E0. I believe it is around 1990 but need to be sure to order a shop manual for this thing.<br />Also I am told that this is really a YAMAHA engine under the Mariner cover...Is this really true? All help is appreciated. :confused:
fone_man
Re: Mariner 30 hp/What year is it?
bwargo:<br /><br />Check all numbers again for accuracy... 30 EO is good but applies to various years!!!<br /><br /> :confused:
bwargo
Well the only tag on the motor is on the bracket that holds it to the transom. It is a metal plate that says Model: 30E0 Ser: 108426 Code 69S. They are the only numbers on it. :(
fone_man
Here you go... all the info I can find on 30 HP Mariner... as you can see no 69S.<br /><br />30 M 689-000366 - 689-003780 1979 <br />30 ML 689-301911 - 689-305230 1979 <br />30 E 689-100251 - 689-100850 1979 <br />30 EL 689-401216 - 689-402385 1979 <br />30 M 689-003781 - 689-009510 1980 <br />30 ML 689-305231 - 689-310080 1980 <br />30 E 689-100851 - 689-101955 1980 <br />30 EL 689-402386 - 689-404845 1980 <br />30 M 689-009511 - 689-013120 1981 <br />30 ML 689-310081 - 689-313690 1981 <br />30 E 689-101956 - 689-102905 1981 <br />30 EL 689-404846 - 689-406690 1981 <br />30 M 689-013121 - 1982 <br />30 ML 689-313691 - 1982 <br />30 E 689-102906 - 1982 <br />30 EL 689-406691 - 1982 <br />30A M 689-017076 - 689-020948 1983 <br />30A ML 689-317241 - 689-320184 1983 <br />30A E 689-103586 - 689-104757 1983 <br />30A EL 689-408946 - 689-410819 1983 <br />30A M 689-020949 - 689-024556 1984 <br />30A ML 689-320185 - 689-323526 1984 <br />30A E 689-104758 - 689-106354 1984 <br />30A EL 689-310820 - 689-413868 1984 <br />30 M 689B-004301 - 1985 Marathon <br />30 ML 689B-303783 - 1985 Marathon <br />30A M 689-024557 - 689-027666 1985 <br />30A ML 689-323527 - 689-326881 1985 <br />30A E 689-106355 - 689-107568 1985 <br />30A EL 689-413869 - 689-416198 1985 <br />30A M 689-027667 - 689-029862 1986 <br />30A ML 689-326882 - 689-329446 1986 <br />30A E 689-107569 - 1986 <br />30A EL 689-416199 - 1986 <br />30A M 689-029862 - 1987 <br />30A ML 689-329447 - 1987 <br />30A ELO 689-418125 - 1987 Oil injection <br />30A EO 689-108309 - 1987 Oil injection <br />30 M 689-030686 - 689-033487 1988 <br />30 ML 689-329959 - 689-332607 1988 <br />30 ML 689B-304693 - 689B-305382 1988 Marathon <br />30 E 689-108559 - 689-109279 1988 <br />30 EL 689-418520 - 689-420354 1988 <br />30 M 689-033488 - 689-036667 1989 <br />30 ML 689-332608 - 689-336183 1989 <br />30 ML 689B-305383 - 1989 Marathon <br />30 E 689-109280 - 689-110015 1989 <br />30 EL 689-420355 - 689-423270 1989 <br />30 M 689-036668 - 689-231305 1990 <br />30 ML 689-336184 - 689-531215 1990 <br />30 E 689-110016 - 1990 <br />30 EL 689-423271 - 1990 <br />30 M 689-231306 - 689-232775 1991 <br />30 ML 689-531216 - 689-532960 1991 <br />30 M 689-232776 - 689-234025 1992 <br />30 ML 689-532961 - 689-534425 1992 Sold intnl & Canada only <br />30 ML 689-533206 - 1992 Sold Japan only <br />30 ELO 689-551576 - 689-552225 1992 Sold intnl & Canada only <br />30 ELO 689-551676 - 1992 Sold Japan only <br />30 EO 689-250856 - 689-251025 1992 Sold intnl & Canada only <br />30 M 689-234026 - 689-235090 1993 <br />30 ML 689-534426 - 689-535640 1993 <br />30 ELO 689-552226 - 689-553065 1993 <br />30 EO 689-251026 - 689-251315 1993 <br />30 M 689-235091 - 1994 <br />30 ML 689-535641 - 1994 <br />30 ELO 689-553066 - 1994 <br />30 EO 689-251316 - 1994 <br />30 0G116485 - 0G290584 1995 <br />30 09831775 - 09884850 1995 <br />30 0G290585 - 1996 <br />30 09884851 - 1996 <br />30 Jet 0G116585 - 0G290584 1995 <br />30 Jet 0G290585 - 1996 <br /><br /> :confused:
bwargo
fone_man I sure hope you did not TYPE all that stuff just for my sake!!! My goodness I am definately going to print that out!! <br />I had to get an ignition module this summer(CDI BOX). I got 2 pieces wrong because the local dealer said that my serial number was no good at all.I can't figure why this is such a busride! I eventually got the right part but was then told that the 69s meant that it was a Yamaha engine under thr Mariner name for that year or so. I will take your information and go all over the engine in search of another number! Thanks alot for your time and help.<br />By the way where is the best place to get the best shop manual.<br />This engine keeps blowing out the CDI ignition box and I can't figure out why... :confused:
fone_man
I have checked all my sources so far... I have come up with the 2 digit numerical & 1 digit alpha EX: 67F under Yamaha but everything under Mariner is coming up 3 digit numerical EX: 689... I am at a loss. That does't mean your number is not correct, just a fluke that is not published.... As for typing all info in post... that is what "control + C" is great for... COPY!!!!<br /><br />Sorry I could not help but I will keep it on the back burner!<br /><br /> :(
bwargo
fone_man...I found a better number sequence on that Mariner 30 hp that you were helping me out on last weekend. It is a Mariner 30 hp Model : Mar 30-EO SERIAL number is: 689s108426. It has an OIL INJECTION cover on it.From the information you gave me is this a 1987??<br /> Thanks,<br /> Bill<br /> :p
fone_man
All Right!!!<br /><br /> :D
