Hi folks, first post from a newbie and novice boat owner
I have the Mariner III engine on a 6 meter RIB so there's plenty of power. However when I push up above 3.2k rpm for more than a minute the overheat alarm sounds so I figure it's time to look at the impeller.
WHen I look at the lower half of the Mercury Magnum engine to get to the pump I can see three forward facing bolts that are easy to remove but remioving these doesn't completely free the lower assembly.
However at the back of the engine directly above the prop is a pitted circular disk which I guess is the anode, and I think there must be a dourth bolt hidden somewhere behind the anode disk so I also need to remove it first. Question is, how is the anode plate secured and removed? Directly above the plate is an access hold protected by a plastic grommit plug which I can remove, then there is a void inside the casing of about 6 inches down to the other side of the anode plate I can't see what is securing it. Is there a screw, a nut? Is this the right way to remove it? Or have I got it all wrong?
All impeller change help welcome! THanks guys.
