Mariner 15 2 stroke OD158038
thatone123
Banned
I know these classics were made for quite a few years as I have a like new 89 and this one, not sure what year, but all were the same or very similar as far as I can see as I have seen a lot of them as they seem common. They plate on the motor sez they were made at the Midwest plant. Does anyone know if some were Jap motors, especially Suzuki? I just cleaned the carb on this one, then had a hell of a time starting it. Finally got it going and will see if it is easy to start the next time. Some don't like the carbs on these? I have used the OMC 15 2 strokes in the past and they weight 74lb. The Merc/Marine weights only 71 and ounces count in waterfowling at least the places I go. It seems to have the power of the OMC, but not maybe the Torque. The next range up in hp 20/25 are similar too, just bigger.
flyingscott
That # comes up as a 1992. Your motor is an american made motor not built by yamaha. When yamaha was building motors for mariner in that size they were Re-Badged Yamaha motors. The carbs are fine the worst part of that motor is the crappy lower unit they stuck on it. Make sure you check the fluid regularly in the lower water kills them.
