Mariner 115hp lower unit removeal
Chris1956
Re: Mariner 115hp lower unit removeal
Well, I think the mystery may be partially solved. If the prop won't come off, the motor has been in salt water for a while. Try a 2X4 and pry the prop away from the gearcase gently, alternating between prop blades. I recommend you tilt it up and soak the propshaft splines with some penetrating oil.
Pulling the powerhead will not help IMHO. I doubt you will budge it with the gearcase still attached. Use some wood wedges to get some separation between gearcase and midsection, hang the mother upside down, with the powerhead 1 inch off the ground, and spray the crap out of the driveshaft with penetrating oil. The goal is for the oil to drip into the crank/driveshaft connection and loosen it.
Rickyroo
I was able to get the prop off however it had some kind of sticky stuff on it. I was able to clean it off but I had to scrap it off. I think who ever worked on this motor before my may have used the same stuff on the drive shaft as well and that is why it will not come apart. I was only able to get the prop off after using some heat and brute force.
No , the drive shaft splines are usually greased.-------But folks still assemble these dry and without the o-ring seal in place.----That is why you now need an atomic bomb to get it apart.
Chris1956
The stuff on the propshaft may have been Perfect Seal. That is recommended by Merc. Merc doesn't recommend it for the driveshaft though.
Rickyroo
I guess I will just keep prying on it and using heat until I get it all pulled apart. I just hope I don't damage anything that can not be repaired.
