rick watling
- Mar 12, 2006
- 3
I'd like to know what the best marine plywood is for structural applications. Should I get the "Joubert Okoume" or a cheaper product??
Be Careful,...........<br /><br />The Transom Thickness,.... HAS to be between 2",+ 2 1/8th" Thick for that Mercruiser.........<br /><br />No More, & No Less..........also I want to add a layer on transom to beef it up.
Thanks Andy. You demonstrated the issue I was having at the time. When I found it, it wasn't the right size. I needed 3/8" for my previous boat. I will go to those listed for a transom I am replacing....ThanksOriginally posted by andy6374:<br /> The first place I looked had actually (maybe luck). <br /><br />-Eagle Lumber in Warwick, RI on Post Rd.<br />$79.95 for 3/4" and less for 1/2"<br /><br />It's A-B marine grade fir. (A-B is what you are looking for, B-B is alright if that's all you can find_<br /><br />-Arnold's Lumber in Wakefield, RI on Main Ave.<br />$...very expensive couldn't remember the price but it was more expensive than eagle.<br /><br />-Alantic Plywood... it is in North Providence, RI (I think).<br /><br />There could be more, but I didn't research it that much. I would deal with Eagle Lumber if I was you, they usually have 8-10 sheets of 1/2" and 3/4" in stock.
