Tafflad
Thread starter- Joined
- Oct 23, 2007
- 548
I fitted a Tower to my boat this year, or in fact the dealer did.
I'm very pleased with it.
What I intend doing out of season is laminate in some supports behind the deck fittings, to cut down on flex, and strengthen the support point.
Intent is to glue in some 3mm ply - about 60cm x 20cm been advised, with fixing bolt through the middle. ... that is 1/8" of 24" x 8" for those not yet in 21st Century...
Once glue has set, glue in a second layer over the first.
Advised to use 3M 5200 as the adhesive.
The Q ... should I be using Marine ply for this, or as this is well above the water line, is WBP ply good enough.
I could always put a coat of yacht varnish over the ply & edges once fitted.
