Re: marine grad wood or treated plywood for my transom?
heres a tip sam, take that pressure treated wood you bought and build a house or something with it. pressure treated wood is different than marine grade wood, pressure treated DOES use different glue than marine grade. pressure treated wood should NEVER be used in marine applications UNLESS, you are using it somewhere it will be exposed to the elements. <br /><br />now go back to the hardware store and tell them you want a sheet of 3/4 AC, dont settle for BC. wanna know why ? ok, pressure treated wood is not a good choice for something you are going to fiberglass around. pressure treated wood is very wet, you already know this much. what happens when you fiberglass wood, the wood absorbs the fiberglass rosin when you apply it, this is because the wood is dry. AC plywood uses a waterproof glue and is acceptable for marine applications. pressure treated wood will rot eventually if its on your boat and it gets wet all the time. if you do a good job fiberglassing the boat, ANY plywood will stay dry. go ask them to show you a sheet of high dollar marine grade ply, i guarantee you it wont be dripping with additives like pressure treated. there is a glue called gorilla glue, its like 5 dollars for a bottle. you can glue two sheets of 3/4 ply together with this stuff and it will be as strong as one sheet of 1 1/2. please dont use that pressure treated wood on your vessel, the fiberglass will never form a good bond to the wood and it will start to crack and break off as the transom is stressed.<br /><br />any wood will stay dry if its fiberglassed properly. <br />marine grade, pressure treated, cheap stuff, will all have a very short life if exposed to the elements.<br />AC plywood IS exterior wood, the glue is pretty much the same as marine grade. and a sheet of 4x8x3/4 is about 55 60 dollars, a sheet of AC is around half that.
