FORUM RULES UPDATED - - - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for . . . Forum Rules
yes u cant make hollow castings without holes in them.. the core plugs just fill up the holes.. and i have seen mercedes engines with solid threaded ones that actually screw in..<br /><br />protecting against freeze damage isnt what they are there for.. but no doubt some of em popping out have saved quite a few engines over the years..<br /><br />trog
No thin wall auto block is really going to stop ice from expanding at the expanding temperature range. You have to remove the water or mix it enough with anti-freeze. Only 2 ways known.
Originally posted by trog100:<br /> <br />i am pretty sure the one i could see was steel.. dont know about the rest cos the engine (except for the rear end) is all nicely covered in the original black paint..
good idea hystat.. its something i do to make sure stainless steel really is stainless steel.. he he.. never occured to me to use one on the core plugs thow..<br /><br />trog
most of the factory blocks come with steel freeze plugs
which doesnt like salt
even whan they install brass freeze plugs the large one is steel
not exposed internaly to water and they rely on paint on the ex to protect
the cam bearing plug on the outside
the block may hold for years or days but even if it cracks and doesnt
enter block it will still present a possible cooling prob.
benny1963
