After much debate on the subject, I did some investigating, heres what I found out (350 chevy) some earlier mercruiser blocks (not all) had a higher nickel content, the marine spec Camshaft had ten thousandths more intake valve lift and held the exhaust valves open for 8 degrees additional crankshaft rotation, (some not all) 350 volvo and mercruiser engines had steel cranks (late model magnums do) So I would go ahead and use a passenger car or 4 bolt truck block without hesitation to build a marine engine, you'll need a fel pro marine gasket set and a marine ciculation water pump, brass freeze plugs and the marine spec cam if you're trying retain similar out of the hole horsepower, these cams are by no stretch of the imagination bumpy, I honsestly see a 10 to 15 horsepower increase with the mercruiser spec cam as long as you are using a marine distributor, carb, and fuel and water pumps you'll have no trouble with one of these blocks, bare in mind though if you choose a late model say '98 or '99 350 vortec there is no provision for the mechanical fuel pump and you'll need an electric pump anyone who wants the specific lift and duration cam specs you can get them from your seloc manual or go to the iskendarian website like I said the cams are hardly bumpy, I just installed a '98 350 in a searay 22'open, my buddy says he see's no difference in time to plane and a 6 mph increase in top speed, and we used the stock chevrolet truck F.I. camshaft So beleive what you want, and if you're interested you can buy a brand new 350 early casting engine from your local Chevrolet dealer and change out the gaskets and anicular components and make your own marine version of a smallblock chevy for a boaat thats going to run at relatively low rpm such as a ocean fishing boat I really don't think the extra valve lift and duration is going to make much difference if you're not shure ceck with an engine builder as far aa camshaft selection here's a link for some engines if you look carefully at this site you'll see they also have new not rebuilt chevy long blocks for 1500.00 and change http://www.rebuiltmarineengines.com/ http://www.truckengines.com/ these guys also have popular diesel engines
http://www.truckengines.com/new.html
