kinematics
- Jul 22, 2012
- 11
Hi,
I need to pick a alternator for my 1976 General with a OMC electric shift outdrive and 1966 Ford 289 engine. I'm converting the engine to fuel injection and will be making my own wiring harness. I've spent considerable time reading about marine alternators and charging circuits but still overwhelmed with all the different options. I'm favoring a Delco 10si 3 wire alternator, but don't have enough information to make a decision on power output needs or compatibility with my mounting brackets. Due to the lack of a charge controller and mnimal electricity need, I feel a 60-70 watt output would be ideal. I'm concerned having a 100+ watt output alternator without a charge controller will decrease the life of my battery due to overcharging. In addition, I can not find a answer if any of the alternators I've looked at will work with my mounting brackets. I suspect my brackets are designed to be used with any alternator but not sure. I've attached a photo of a very similar bracket setup. Am I over analysing, should I have other concerns?
