VaGent
Thread starter- Joined
- Jul 14, 2008
- 221
I have a 1984 JC 24' pontoon boat rated for a 90 hp engine. The transom is "inset" 45 inches taking away a lot of usable deck space. I plan on using a Johnson 70 hp engine instead of the 90 which I understand is about 50 lbs lighter then a 90 engine. I want to move the transom back so the engine is behind the stern of the boat thereby giving me needed deck space.
I have the aluminum "Z" bar cross members which happen to be heavier then the original ones from the factory & there is plenty of mounting surface to attach them to. I will be adding one (1) additional cross member which will place the transom approximatly 15 inches from the added cross member. By doing this not only will I gain added deck space but the engine will be in "clean" water behind the rear logs. No welding is required as I am setting it up just like the original setup from the factory which is all bolted together.
Can anyone forsee any problems with doing this & if so what problems could I incur? I'm told this should enhance the overall performance as the pontoon will be setup like most of the new pontoons that are being produced now. Other then possibly a balance problem which I can overcome I can't see any problems with doing this project. Any input from more experienced boaters would be apprciated. The relocation of the transom will be 2 feet from where it is now.
