Re: marine 3 m sealant 5200 (not the fast cure kind)
hey everyone, i just used marine 3m 5200 a couple days ago to seal up my keel where it was thinned down and a bit leaky, how long should i expect it to be fully cured? also does it dry hard? or is it always some what squishy? like does it ever dry as hard or even almost as hard as say jb weld??
thanks
I think you should be asking how long Resin and Fiberglass will shelf for .. or how long does it take for Resin to cure.
If your keel was that thin you should be using Fiberglass.
As for the 5200 it should be cured in 7 days if im not mistaken. But you can put it in the water at anytime after the application.
It does not get hard as JB weld.
As far as the longevity of the tubes .. you can still use the product inside if you cant get it to trigger out of a caulk gun. Just stab it close to the tip and squeeze it out..then after that dries you cut a little lower on the opposite side of the tube. .. rinse and repeat until you have to just cut it completely open at the bottom. I have tubes from years ago that I can still use
Oh and they do sell 5200 in small toothpaste type tubes
YD. Hope you get back to us on that 5200 Vs. Fiberglass thing.
