Re: Manifolds & Risers....What am I getting into?
Heat works great on stuburn bolts,but be carefull of open flames under a motor hatch. This is why they install blowers on those inboards and I/Os.<br />Just a caution in case you didn't allready know about it.<br />Lots of WD40 werks well on the white corossion you will encounter. It desolvves it.Spray everything with it,and let the puppy sit overnight.Then spray it again before twisting ("twist n Shout" is what my wife calls it).<br />It is not an easy task, about as hard as replacing a head gasket on a car.<br />But if you can do that, you should have no real problems you cannot surmount.<br />A large rubber mallet is one tool I know you will need,along with a breaker bar, torque wrench, and gasket scraper (razor blade).<br />It would be a good time to replace all the freeze plugs you can reach too.
