jerryjerry05
- May 7, 2008
- 18,196
Re: Manifold Replacement
Your gonna need to drain the whole motor.
The block and the manifolds.It's easier to remove the risers then the manifolds.
If they aren't drained it can run into the exhaust.
You'll be surprised how heavy they are.
Some manifolds have studs with nuts,some have bolts.
It easier to replace the manifold if there is a stud you can put it on.
A 6-7in. piece of all thread works real good.
And remove the plugs.One little slip and they can break.
If you don't drain the block it's possible the water can get into the exhaust ports???
It's easier to work on a motor with out it dripping and water running all over.
