Mallory or serria
tashasdaddy
Re: Mallory or serria
equal they are both aftermarket.
filycheese
welli need to get piston powerhead gasket set and berrings for the rist pin should i go with original
Sea18Horse
With the possible exception of the gasket set you'll have no choice but to go with OMC (or BRP nowadays) for that stuff. Sierra and Mallory service mostly maintenance items like water pump impellers, carb kits, tune up kits and coils. Stuff like that, for hard parts you'll probably need to go with factory stuff. Good luck!
Cheers...................Todd
elhombre
fyi, I just finished a 150hp v6 overhaul and was able to get everything from iboats. pistons, rings, bearings, powerhead gasket set, and h2o kit. all were sierra aftermarket. I've since heard the pistons may last 150 hrs, I dunno. I did this rebuild quick and cheap, but I'm back in the water w/about 8hrs on the motor so far. I believe oem is best, but sometimes circumstances dictate alternatives. have fun with it-- Mike
filycheese
i ended up going with oem everything thnks for all thehelp
Dhadley
Just for the record, Mallory does have engine parts like pistons, bearing, gaskets etc. Not just maintenance items.
