MaKenzie Cherokee
Steakin
I got a Makenzie Cherokee 14' aluminum boat I was wondering if anyone knew the year and the model, I attached a photo of the boat and of tags that I found on the transom, it appears to have had two bench seat in it at one time by the brackets that where left.
im going on a limb and saying 1959
what does your paperwork say it is (title/registration)? without paperwork it may be a yard planter model
cool little boat.
Steakin
I did not receive any paper work with the boat, what are you saying that without it I won't be able to use it on the water?
jbcurt00
Yep, depending on where you live, thats exactly what he meant. Some states are extremely difficult to deal w if you dont have title and/or registration for boat and trailer. Some states title outboard motors as well.....
Steakin
I did some research and michigan does not require a title for boats under 20' and with an outboard. Does anyone know how to decifer the hin numbers for a Makenzie Cherokee.
HINs came about in 1972. Prior to that was serial numbers
Good luck
Steakin
Thanks Scott that's what I figured I found some pictures of a 59 Cherokee and mine does not fit the bill. Mine has the cross member between where the rear bench seat would be and the splash pan is, I have yet to see one with that cross member but I believe that 59 is close based on the the location and style of the side sticker.
