I'm in the process of stripping down and rebuilding a 1959 Evinrude 5.5 hp outboard motor. At present, I have removed the carburetor, intake manifold, head, flywheel, magneto, armature plate, and starter hood. Aside from pulling the head off, the powerhead is still intact and on the motor.<br /><br />I'm wondering... How difficult a job is it to remove the powerhead to inspect/service the pistons, bearings, rings, etc.? I feel like I should do this since I'm so far into the engine already, but is it unlikely I (a novice) can do a good/accurate job servicing and reinstalling everything without sophisticated equipment to measure bore, wear, etc.? Should I be taking the powerhead to a small engine repair expert instead? (Yes, I do have the Seloc manual, by the way).<br /><br />Next, the spark plugs I removed from the head (2 of them) do not match exactly. One is "J6C" and one is "J6J"... The Seloc manual specifies "J6J", so what is the "J6C" plug? Do the top and bottom piston really use a different plug, or is one of them improperly installed (I just bought this engine from a marina, haven't run it yet), or is "J6C" a new code for essentially the same plug?<br /><br />Also, the 2 coils on the magneto do not match. One appears to be coated metal or ceramic (hard rough texture) while the other appears to be a (newer?) plastic coated coil. I'm guessing one is a replacement put there by the last person to service the engine, so could this be why the spark plug codes don't match? Should I be replacing the other coil and plug?<br /><br />Lastly, any tips for removing stuck screws that go into the exhaust cover and the powerhead? Some are EXTREMELY tight and refuse to break loose.<br /><br />Thanks so much for any feedback,<br /><br />Wes
