Magic tilt trailer floats
striper chaser
My trailer floats and it makes it quite difficult to load It is aluminum I beam dual axle with with wood skids any ideas how to solve the problem.
blifsey
Re: Magic tilt trailer floats
No idea but I know of a blonde in a brand new bayliner that might trade trailers with you. Her trailer doesn't float and it keeps her boat from getting on plane. :D <br /><br />BL...
SoulWinner
Greetings,<br /><br />Since the trailer is made of light weight aluminum, I believe the problem is overcoming the buoyancy of the tires. To figure this, you could take a off the trailer and see how much weight is needed to sink it in a wash tub. Then guess at the distributed weight of the empty trailer, subtract that from amount needed to sink the tire, multiply by four and............golly, this is more complicated than a space shuttle launch. How bout this: Launch the boat, get some folks to stand on the railer until it sinks. Figure out how much the agregate wieght is and add that much weight to the trailer at the axles (so the C.G. for the trailer remains the same for towing purposes). For weight I would suggest bolting sections of rail road track to the inside area of the frame. It is heavey (70 pounds per foot) and cheap (if not free laying around the local tracks). Lead is expensive, but is corrosion resistant. If you use steel to add wieght, Por 15 is a great rust prohibitor. <br /><br />Good and God Bless,<br />SoulWinner
ndemge
My dad adds windshield cleaning solution to his tractor tires to help when mowing on hills.<br />and it doesn't freeze in the winter.<br /><br />but keep in mind, that thing goes 12mph...not 70.<br /><br />the RR track thing is probably the easiest route<br /><br />oh, oh..I know... just deflate your tires when you get to the ramp. Duh, why didn't I think of that earlier
striper chaser
Hey there guy's, I'll try the railroad track affair first, sounds like that would work fine. <br /> Mucho Gracias
