Lund Alaskan inboard tank question
Diceros bicornis
What year did Lund go to the built in gas tanks on the Alaskan? Specifically interested in the 18 and 20 foot models. Anyone have one with the inboard tanks, advantages/disadvantages, comments?
StrykeKing
Re: Lund Alaskan inboard tank question
Not sure when they came out with built in tanks, but my 1800ss feels more stable having the tank more midship as apposed to portable tanks at the stern. As with any built in tanks be sure it has a water separator mounted, some newer outboards have small ones under the cowl but that's not enough in my opinion, and keep it at least three quarters full over winter to help eliminate water condensation.
Gopher
my 2003 Alaskan 18 tiller has the inboard tank, of course, and I greatly appreciate not having separate tanks cluttering up the floor.
On the other hand, my "standard" cruise in the San Juans uses up just enough gas on the outbond leg that I end up *having* to stop by Friday Harbor to gas up instead of worrying the last portion of the return leg. So I may end up with jerry cans underfoot afterall...
For awhile I had a manual shut-off value in the gas line. When I decided to simply to a single hose from tank to bulb-primer, I took up the floor to attach the tank end. The factory hose was a direct shot from tank fitting to guide-tube in hull, with a bit of a sharp bend in the hose.(not quite a "kink" and i suspect it would work for the life of the boat but my replacement put a gentle loop around the tank fitting so the hose would have no side stresses. So this is not a problem report but just something for you to think about if you have an excuse to pull up the floor anyway.)
cheers, g
My 2003 20' Alaskan tiller has a 27 gallon built-in tank. I love the extended range and no-clutter. Not nice when it comes time to fill but.... hey, what ya gonna do?
E
