Home Cookin'
Thread starter- Joined
- May 26, 2009
- 9,715
My motor started a bad rattle in the LU this weekend comnig in from fishing, got worse. at lower speeds you could hear it and feel a sort of galloping motion. Prop was a little loose so I tightened it, no help. Pulled it out and pulled the LU drain screw, to find an inch-long icicle of metal flings on the magnet. Closed it up and dragged it to the shop; this repair is beyond my skill set and time quota.
Mechanic, just on the above info, guesses it will have to be rebuilt, and that it might be cheaper to replace the whole LU gear case; they'll give me the options once they see what's in there. This is a reputable shop, but expensive.
Any general thoughts on which would be better, if replacement is not that much more than rebuild?
If I replace, should I keep the old gear case? I don't want to have a lot of junk parts lying around, but it seems that the case itself should be fine and could be useful if I damage the other one (but how likely is that, in a sand/mud environment?) Other parts in there worth keeping? prop drive shaft, etc?
I think I'd rather not replace it with a used unit, although I do that some with my cars, but I may be able to get one, condition unknown, from a local used boat junkyard.
2003 150 Yam 2 stroke, carbed. I've put 270 hours in about 2.5 years; previous owners didn't use it much, so they say.
thanks!
thanks!
