Lowrance Structure Scan LSS-1 Box
Jean Lafitte
My structure scan gives me a "No Source" message and I can't figure it out. I have checked the power cable and it is hot. Both yellow and red. There are no LED lights on the LSS-1 box and apparently there is supposed to be. Could the box be bad???? :confused:
sandiegosteve
Re: Lowrance Structure Scan LSS-1 Box
Check the power line to the LSS-1 with a volt meter. Did you put the fuse in? Did you hook up the yellow wire?
There are two options for the yellow wire; 1 is to splice it with the power, the other is to hook it up to the HDS unit. Bottom line, it needs to be on a hot circuit to power up the LSS-1. You will see blinking LEDs when it is on.
