lowrance Lxc 112 gps fishfinder
marty f
i have the dual freq 50/200 transducer and i cannot get my water temp guage working help someone
Barnacle_Bill
Re: lowrance Lxc 112 gps fishfinder
Did it ever work? Are you sure your xducer supports temp readings?
marty f
its new and yes it is a temp sensor too
Bass Tracker TX17
If they support the water temp you have to have the right transducer.
With all the stuff loaded into these things it could have to setup in order for it to work.
my old one did not have a temp but if i upgraded to another transducer it would
show up.
If you double check the transducer number and the setup and it's ok then you have a defective unit or transducer.
did you change the whole thing or just the transducer ????
Bass Tracker TX17
if I'm reading that right that's not a dual freq. but temp is available.
I'm wondering if trying to run dual freq on a non dual would mess up the input.
If he got a Part #106-71 then his temp wouldn't work because it doesn't have the sensor.
just throwing out ideas. Had friends with misboxed accessories and options wouldn't work.
i'm thinking Part #106-77 is what he should have...
Boatist
Marty
Put the unit in the sonar full screen.
Hit the menu key.
use areo keys to move down and highlite OVERLAY Data
Hit Enter key
use areo keys to select temperature
Hit enter
if it give you size select size and then hit enter.
Exit all the way out
Temperature should now show.
