Lowrance Combo Models Fuel Flow Question
tboltmike
I am looking at a Lowrance LMS-527C DF iGPS and one review said that it does not use the internal gps to calculate MPG with the data from the fuel flow sensor...the external gps antenna is needed.
Can any of you confirm if this is true.
I have seen the Lowrance 5300 Ci gps. Which one of these is the newer model? and does one have an advantge over the other?
Thanks, Mike
bruceb58
Re: Lowrance Combo Models Fuel Flow Question
I have the older model of that GPS and it is true with mine that you need the external GPS antenna. For that reason I ordered the external GPS antenna model. You can still get fuel flow but no MPG which was an important feature for me.
tboltmike
what sort of display does it show on the screen when looking at fuel mgmt?
Thanks, Mike
bruceb58
I just add digital data to my displays, depending on what i have up. The newer model smay be diffrent.
