Lowrance blue connectors - unknown fishfinder 1997
appleo
Picked up a used 1997 Grumman tinnie last week Fishfinder is missing.
Two cables appear to be Lowrance with the Blue locking collars
I see a transducer and a speed paddlewheel on the transom
Grumman brochure from 1997 suggest it may have been a Lowrance X-22A
Anyhow I would like to understand what old Lowrance models would plug and play with this cable set
Thanks for any help
gm280
I read your question and it seems like you are wanting a locator that fits the connectors and transducer so you don't have to change them. Isn't that a reverse method of buying a locator. I would think you could buy a new unit and reinstall those items and be way ahead of the curve. If you never run wires in a boat before, you can easily tie off some string on the power connectors and pull them through and then use the string to pull the new wires and connector back through to the installation area. Same with the transducer.wirering. It is done everyday that way and easier then you may think. And a new unit would have both updated technology and a warrentee. JMHO
