lower unit
tim yaden
ive got a 50 hp evinrude that acks like something is slipping its not the prop had prop fixed it slips you can back off gas then you feel it catch then you can go till it starts to slip
Tracy Coleman
Re: lower unit
Have you owned the rig for a while, and did it ever run "normal"? You can have a prop repaired and not replace the rubber hub. Sounds like a slipping hub, what type of boat, barge, bass?<br />Backfire ;)
waterinthefuel
Re: lower unit
We had this problem and it turned out to be air getting around the prop instead of going through it. Does your prop seal well against your lower unit? Also, is your cavitation plate even with the bottom of your boat? If it's a hair too high it will do what you describe.<br /><br />Keep us posted.
5150
Re: lower unit
Does it make any noise when it slips or do your rpms just pick up?<br />Does this happen at any speed or just when you are going faster?<br />I know my boat when you trim it out to much the prop will suck air and it seems like it is slipping.<br />It could be as simple as dropping the motor down a notch or two or it could be gear related,if it makes any noise whatever don't run it until you get it fixxed,lower unit parts are extremely expensive.<br />I rebuilt my lower on a50 horse Evinrude last year and just the parts were over 300 and that was only two gears,the whole set is @400-500
OBJ
Re: lower unit
Tim....welcome to the iboats forums....<br /><br />When the problem arises...does the engine rpm take off and you go nowhere or...is there a bump like hitting a log in the water?<br /><br />On two different occasions, I have sent props out for re-hubbing. They came back and when installed, the hub still spun. Put a spare on or maybe borrow one and try again.<br /><br />Keep us posted.
tim yaden
Re: lower unit
the boat is a bass boat i havent had it very long the guy i got it from said everything was fine it sat for about 2 years when i had prop fixed they replaced rubber hub there is no noise when it acks up its my first boat so i dont know much about boats the ruber hub looks fine cant tell if is slippingor not the motor shackes when it slips
