Lower Unit
reddwarfau
Hi, Hope this is the right place. I have a Evinrude Elan 35hp. I am trying to take of the lower unit (we call the leg) to replace the impeller, I cant get it off. I have tried in forward, nuetral and reverse, no luck. I cant find any pins, clips etc to remove. Help ( this is an Australian model BE35AREDG
175se
Re: Lower Unit
if you have all the bolts out remove the plastic water intakes on bottom of gcase in there you should see the coupling to disconnect the shift mech. once disc slide upper connector up and remove little plastic collar (its a split collar don't take much) off comes gcase. just for kicks my code book says its a Belgium erude 35 rope start -Alaska 1996
reddwarfau
Re: Lower Unit
Thankyou, that was it. All done
