Re: Lower Unit
twag, in your post, how do you CHANGE the lube? Pull the top vent plug, pull the lower drain plug, let ALL the lube drain. It should be a nice dark color without looking milky. If it does look milky, LU has a leak. It it looks good, proceed. THhe coolest thing out there to replace the lube is a pump. The pump is foe lube in a quart bottle like oil comes in. Screw to filler tube in the lower drain hole, pump lube in until lube comes out vent tube, replace vent plug, with a new gasket for the plug, this creates a vacuum so the lube won't run out the drain, remove fill tube and replace the drain plug, again using a NEW gasket for the drain plug. I was taught not to reuse gaskets. Not spending .50 can cost you 500.00. Use a hand impact to tighten these plugs to keep them from coming out when cruing on the water.
