Lower unit wont mate up
yimmyb
Installed a new water pump in the lower unit of a 1980 Mercruiser sterndrive serial number 5583873. Upon following all the directions in the Seloc manual the lower unit will not mate up. It comes within an inch and no farther.
Bt Doctur
Guessing a Alpha1 , How hard its it to follow Seloc directions, "Place manual on ground , kneel on it"
With the control box in fwd gear and the impeller prelubed and water inlet bushing slightly greased
Place lower unit in fwd gear by rotating the splined shaft fully CW
Raise drive up , slightly turning propeller CCW to rotate driveshaft splines untill splines engage
Make sure lower brass shoe locates correctly on the splines in the lower shaft and is in a straight line "fwd gear"
Install side nuts and snug, making sure upper and lower shoes mate correctly install remaining nuts
Fill with oil from the bottom
CamaroMan
did u turn the prop ? sometimes the gear splines will hook up - its in forward right? so u turn prop COUNTER clockwise to rotate splines - either that or the water hose but prob the small spline shaft.
when its on make sure the fwd/n/rev are working before u button it all up..
JoLin
The sequence is to try to push it on, then back it off, turn the prop shaft a fraction and try again, I've had it slide in on the second try, and I've had it slide in on the 20th. Take a break and do it again. Don't give up.
Ayuh,.... Which is about the length of the spline engagement,...
Turn the prop counter clockwise a tiny bit,...
