skinny1965
Thread starter- Joined
- Aug 3, 2010
- 148
ok its a alpha one and I pulled the lower unit off to install a different water pump and lower unit will not go back in it all goes to about an inch away (studs just at edge of hole no threads out)
it seems every thing is lined up but just not going in. I have checked the shift linkage is ok and seems water tube is in line I have also tried putting in gear and turn to see if spline is out just doesn't seem to go I don't want to force it.
