Lower unit water leak?
Ranger 335v
I took the boat out of the garage today and flushed the fluid in the lower unit. Then I put the ears on it to start it up. I noticed it leaking water around the rear of the unit at a metal cap and around the lower unit seal. It is a 1986 110 hp Johnson. Is this a big deal? If so what is the fix?
Thanks and Semper Fi,
Rod
jonesg
Re: Lower unit water leak?
Water comes out just about everywhere, considering the leg is supposed to be submerged anyway..its normal.
Ranger 335v
Thanks guys. I am going to assume it is normal since I drained the lower unit and refilled with no water in the oil.
Thanks again,
Rod
