Bought boat with 2005 15hp Tohatsu tiller/pull start. No history on prior owner's service. Want to change impeller but cannot get lower unit off. 4 nuts and spring pin holding shift rod have been removed. It does not budge and cannot even see any separation at seam. I've had it hanging upside down for about a week, sprayed PB blaster into water intake hoping some would work down thru pump housing onto drive shaft and into splines at crankshaft.....no luck. I would really appreciate any thoughts on next steps to consider??? Thanks!:facepalm:
