Any tricks on changing seals on a 8hp Yamaha? Found water in lower unit lube. Motor has been out of use for quite some time.Found an O ring on the prop shaft and oil seal on drive shaft by the water pump. Are there any more seals? This is from a Clymer Repair Manual which I find very vague.
