Hi gang, when I changed my lower unit fluid initially, I noticed a very small amount of water in it. The oil in there was a bluish 90w oil. I did something dumb and used yellow 80-90w marine gear oil. So after about 6 hours at the lake on 2 occasions, I drained the oil and found a mixture of green / yellow. This time I used Star trom 90w oil and again ran if a few hours. Drained again today and noticed it to be not clear, either milky or just weird mixture of different oils. What should I do next? Pressure test the unit ? try to swap the seals using the seal kit which I think is this
