I got my first outboard last summer for $50 w/ a gas tank. I replace the lower init gear lube last summer and let the motor sit until saturday when I replaced a tiller and put a carb kit in it. When I put the motor in the barrel and ran it the water had a lot of oil scum floading on the top. So I removed the motor and drained the lower unit. It had quite a bit of water in it.
So the thing sat all summer/winter and didn't leak a drop then when I put it in water and started it I had a mess.
Any ideas or should I just replace all the lower unit seals?
