henning_dt85
Thread starter- Joined
- Oct 19, 2003
- 74
the oil-seal began to leak, so i wanted to take off the lower unit to look at it. It is a salt-water engine. The first screw,okay, then, the other tree broke off. Well,as long as i get the lower unit off it is okay, but it will not move an inch. tryed with a hammer at the cavitasion-plate, drillet 3 hole to get a screwdriver inn, no, didnt work. Do anyone know? If nobody knows, this engine goes to the scrapyard, cant run it with one screv at the lower unit (if it ever will go off)<br />By the way, do anyone know how to remove salted bolts? (sitts like hell). WD-40?
