Lower unit on 60's Merc??
MassDave
How much lube should it take to fill a 50hp Merc and where is the vent hole located to know when it is full or do I use the hole marked flush?
cr2k
Re: Lower unit on 60's Merc??
There should be a separate screw for the vent. Some older engines had a small screw for the vent. The Flush goes right in to the water pump base and is where you would put an adapter to run the engine instead of muffs.
MassDave
Carholme I had the serial number and left it in the boat. I will try to get it. Really appreciated the info. Where is a good place to get a manual then my problems can be alot easier to find out.
carholme
Dave;
Unfortunately for the older engines, we are not left with much choice:
90-25500 All models, 1965 and Prior All s/ns
90-68647 All Models, 1966 through 1974 All s/ns
Gerry
