lower unit oil types
rd2313
Which oil to use? which is the right one?<br /><br />Lubrimatic makes 2 oils, both labeled "lower unit gear lube".<br /><br />One is labeled High viscosity, while the other says Hypoid 90.<br /><br />Whats the diference? is one better?<br /><br />I am running a '95 Force 70 hp.
Lugnut36
Re: lower unit oil types
you posted this question on the wrong discussion topic, this is the trailers section try going to the outboard motor section and reposting, youll get alot more answers there.
