Re: lower unit lube
What kind of gearcase is that? Im assuming mechanical, but is it selectric or??
If mechanical, use an 85-90 gear oil, you need the additives for water intrusion. If it is electric shift, you need the premium blend type C oil. Be sure to change the drain and vent screw gaskets while you are at it.
