Lower unit lube?
c_hawk
I have a 1961 40 hp lark lll, I drained the lower unit lube and was wondering how much lube it holds and the best way to fill it. Also what color should the old lube be, it was not milky, it was dark brown-black and smelled a little burnt.
tashasdaddy
Re: Lower unit lube?
they now have a pump for installing the lower fluid, you fill from the bottom hole until it comes up to the top hole, this is make sure there are no air pockets, then install the top plug, remove hose, and install bottom plug. there are suppose to be sealing washer on these plugs, you can get them at a dealer. the lower lube is dark, and has a nasty distinct smell. the main thing to be concerned about i metal chips, small shaving are normal, chips or chunks are not.
