Lower unit Lube
mcat121212
Good morning. I just need to verify how to check/change the lower unit lube on my 98 Force 120. I've done smaller motors in the past. Is it the same procedure? Drain and then refill from the bottom hole until lube comes out of the top! Is there anything else I need to consider while doing this? Thanx in advance!
D
DJ
Guest
Re: Lower unit Lube
Same procedure, just bigger. <br /><br />Replace the fill and drain plug seals.
